quality fittings and hoses.
you can use a cheap core if you want... as long as the fitting and hoses are A1
personally i'd just go for a non thermo one on a predominantly track car, makes oil changes easier and you wont be driving it round cold like a daily
ok so oil cooler kits, what should I be looking for?
what should I be avoiding?
bout time I started modding the car again..
Pretty much what Hamish said
I had a chat to Trent about it a few weeks ago and he said just becareful of shitty designed cooler cores. As he was using a core than ran 10c hotter than the one he has now.
It saying that Trent runs a el cheapo $80 one lol. This is the one that works
I have your cooler hoses, fittings and that Greddy thermostat adapter here Tony, when are you going to buy that super oil cooler core you are raving about? :P
Track days coming.... ;)
I thought you were sourcing my Cooler core lol
How long you need the car for?
I was thinking about entering Calder.....but a bit low on funds and time atm :(
Toby, take your car to calder drags I wanna see the beast in action!
Are you taking your car there?
Can't say I've ever been keen to go to a drag day
Maybe if SAU VIC organises one this year ill go
Wasn't planning on it, but if you go down I'll come watch / maybe enter cos its cheap as chips anyway.
Will be throwing a twin 3" cat back exhaust on my car soon :D dat v8 burble brah
SAU had one at heathcote 2 years ago haven't had once since I think :( it was forum battle or something, won fastest ford trophy :D
yeah drags are pretty fun, trying to squeeze that extra .1sec out always a challenge and the adrenaline pumps hard when you're racing or about to launch
really cheap compared to track days, and no need for racing licenses which is a bonus
Edited by UNR33L
