yep going good...having all that power it was just toey all the time, you get on the gas and wheelspin....now you can just mash the pedal everywhere ...I guess it would get boring again after a while...
Like tomorrow? :P
Thanks to my late-night kebab habits, I found that two kunce tried to steal my car. Whatever they tried to start it with broke off in the ignition. Worst thing is that they were further down the street working someone else's car over. fuuuuuuuuuuuuuuuuuuuuuuuuuuuuu
I'm just sitting here, having spoken to the cops trying not to be mad. I've realised in the last half-hour how much I rely on my car now that I've my license.
Also, what a great birthday present these guys tried to give me, a surprise and all. A stolen car.
never forget sitting out front of Crown casino one night, watching these guys casually walign along trying to open every car door....we told Crown security who looked completely dumbfounded...So we stood there and watched...a policecar drove past...still we watched..security called somebody, but not in any urgency...
then they got in a car
then they drove off..
the end
the end
hmmm I hate that carpark. can never find my car again.
if pissed enough, would walk around entire carpark pressing remote unlock. sucks for those without it though.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
