so i won't be going up the MBS to see the pool and shiz. grandmother can't be arsed getting them free tix for me.
BUT.
I've got free tickets to the singapore zoo! and also the new river safari attraction.
Edited by xALmoN
some of you boys need a tour in the shit. after that, even shitting on a proper crapper is heaven.
Plattsy ain't never been in the shit. He thinks "The Bad Bush" is between old mama-san's legs.
let me guess to you "the shit" is some ultra hip nightclub that only let people in who do up the top button of their ever so cool and ironic flanno shirts.
BUT.
SG zoo is off the chain...
There is this enclosure in there where you can just go and pat the sloths with no one watching/guarding
In Aust, some little Gen Y asshole would steal them and ruin everybody's fun
1) lern2fullmetaljacket
2) I don't go to nightclubs anymore... too many annoying kids
Would go just to pat the infamous sloth that I see all the time in internet meme's
lol. fair point. once you hit 30, bouncers should stop letting you in for your own sake.
I support this.
Plattsy for PM
They are cool as f**k.
^ To stop going I mean.
Also for those not on Facebook, ran into Dave Chappelle last weekend at a nightclub. No he was not drinking Samuel Jacksons
Which club and which night? Went and saw him on Friday night and he said he'd hit up the clubs around here.
ok so Cihan not available till Friday, bit annoying but getting screwed around a bit with piping fabrication as well... ergh just as long as its ready for Saturday. will bust many balls to make it happen
Yeah it was Friday night
The new Red Heart, at Baroq House. Still the exact same crowd as when we used to go
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
