Mike showed me pics. You have silver ones, yeah? I like my silver ones. Look good on the car. I just don't want to destroy my centre caps, but can't find a tool for them anywhere, what with them being discontinued.
I have 2 sets, silver and black.
I also have issues finding tool for the centre caps.
So my dad, (think 70 year old)
has decided to trade in his hilux.
he has had a variaty of Lux's for past 31 years
his thoughts on a new cheap run around to get him to golf..
a bloody Maloo
how do I politely explain he will look like a tosser in it!
shit I'm too old to drive one let alone him.
speaking to a friend who works at a volkswagon dealership... apparently customer came in for routine service on new gen Golf. "do you know why my golf keeps going through so much oil?" friend spoke to some people and found out the new golfs are designed to use up oil. around 2L per 5,000-10,000kms or something
:wacko:
not sure if trying to keep regular servicing or trying to meet emissions standards/efficiency.
and heard about audi servicing too... blimey. Audi 15,000kms service: $1200. Q7 brake pad replacement: just under $1000 a corner because need to replace rotors as well.
A maloo is only driven by 18/19yo tradies who are trying to use it to chase minge.
Tell him to buy a golf to get to golf.
so they have a tiguan for mum to drive.
in first 12 months spent 33 weeks in the shop.
they replaced gear box twice, seals in something else, to find it was the rear main seal in motor.
note it was not a VW owned center but a re seller, and if you know where I grew up you will have an idea on where the dealer is...
scary thing is he drives soooo slow, as checking out what other farmers are up to, so when he hits the 8-km zone at the edge of town he has to speed up!
:wacko:
thats because Euro cars are usually owned by people that think spending money on cars for no real reason is cool...They like to brag to their friends about how much they spend...As if spending pointless cash is a sign of prosperity...
but hey, whatever helps the economy churn over...
a bloody Maloo
Let him have his fun and sell it to me for cheap when he's done with it.
a bloody Maloo
i wish my dad bought a maloo...
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
