And JB website only has the 15" version, has 16gb RAM vs 8gb for the other 3 above, but also $400 more (and with a smaller screen)
http://www.jbhifi.com.au/computers/asus/n-series-15-inch-touch-notebook-sku-419058/
this ones got a touch screen which explains why it's a bit more $$
Edited by UNR33L
What I assume are the MR2 club are loading their cars into albert park for display
Naturally you must've guessed that because they're all prancing around with their boyfriends on their arm, not because you saw their motor vehicles. :P
And the hair care products
lol so true. dont really see the appeal of going to the F1s at all. would much rather pay a quarter of the price and actually watch some interesting racing with variety.
  • Like 1
I just sit back and watch Mohsens facebook posts about car dramas... it's butt-clenchingly exciting.
  • Like 1
Went for free last year, wasn't bad. Don't mind watching any motorsport as long as there's left and right corners
Nascar is probably the best spectator sport...and it was designed before every flamin mongrel had a TV and cameras everywhere...so back in the 50s It would of been great...but now more people watch motor racing on TV than at the track so its a different ballgame..
found a nice spot on the hill at PI the other day...and its completely different when you can see nearly the whole track, you see people passing and all the action and know whats going on without having to look at a screen or listen to a commentator...
So i can totally understand Nascar.....Its pedal to the metal non stop speed and action
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
