Yes.
Inb4 peeps say xbox something is better.
if I didnt have plans tonight I would jump on and play withchou.
add Leroy_P or LeroyP. i forgot. ive made some custom races me and a friend are gonna take for a spin soon, should join us if the retarded UI doesnt make it too painful.
Well, can't jump online cos no internet at home thanks to these f**king pirates at places Victoria and useless ISP we're restricted to...
6 months to go.
That includes Plattsy ol boy
Grant, you have no excuses but to deliver
Birdsie you too, and no I don't care if miss Leesh slaps you so hard that you suddenly develop amnesia of the hot GP bishes you took for your QLD Frenchman
Has anyone seen the Need for Speed movie yet? Thoughts?
I would've expected a Coburg drive-ins meet, but no one seems to be keen :(
Cos Coburg is where all stolen cars are taken from.
To all my Victorian PIC. I demand pix of sexy racing queens at this weekends GP!
Just cough up couple hundred and fly down. Could assist you with fapping needs I.e. Tissues, ky jelly/Vaseline and a camera.
anyone know the generic nissan exhaust stud size?
im getting conflicting info with KAs, SRs and RBs. M8 or M10? 1.25 thread?
need studs with thread longer than 47mm (apparently you can get 52mm but havent found anything so far)
Just for you I pulled a brand new genuine stud out of my 25 head and measured it.
They're exactly 50mm.
approx 13mm thread on head side, 22mm thread on manifold side.
Hope this helps
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
