is it now the time that 20's have become practical.
wow i remember when 16's and 17's where coming out on factory cars and we all thought they where huge.
in short.
i feel old.
I had 17" wheels on a VL and used to get compliments for them lol
Tyres were exxy, too.
It's a bunch of commodore bogans and 18-21yo's with imports and street drift weapons having a circle jerk and then one of them does a burnout even though they know it'll end the meet and ruin it for everyone. Not worth attending, though, they do get some damn big attendances. I've seen several hundred cars easy...
Ahhh ok.
It's basically the same as a lot of official SAU events, only with a far bigger attendance and more variety of cars and bikes. It's also quite well organised with music, coffee, professional photographers etc, and usually a co-operative TMU presence.
But as it's not an official SAU meet, of course it's shit..
Hmm sounds good, negative police presence was my worry
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
