whisky sour.
only cocktail a man can drink.
Incorrect
Vodka Martini?
Shit yeah... Belvedere, Noilly Prat, Franklin.
also Old Fashioned is manly enough...
Man I love that housing thread them fools still peddling negativity brings z the lols
Depends man... you should see some of the bad property descisions I see at work :P
my alcohol consumption isnt influenced by rappers unfortunately.
^ This guy.... doesn't even sip criss (or whatever drink the marketing department is paying him to have in his hand while he hits rihanna)
Edit: bahahaha, this just popped up on facebook as someones status... Very related.
"Stephanie : let's get grilled for dinner!!
Emma : YEAH WOO
Me: nah I don't really like grilled man
Steph: I swear you are the reason men hit women sometimes."
  • Like 1
Used to be all about tanq10 martini's... these days prefer belvedere.
sometimes I still go for hendricks + cucumber though
And rappers never influence my alcohol choices... I have better taste than those cashed up hood rats
  • Like 1
farkin lol.
what you putting a shift kit on?
Another 35 Stagea, there are more Stagea's being done up than Skyrines these days.
More Micra's than Skyrines getting modified these days actually. :P
skyrines have been done to death, people want a challenge!
still trying to convince wife to get a stag, she laughed when i showed her picture.
le sad.
le sad.
Aw, poor you.
le sad.
Starting to see a few stags on the road lately.
Couple mates have restored their project stag - super fun car to drive :D
What if you just buy one, and then show the wife?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
