Twice in two days have lost traction completely when leaving Knox turning onto Stud Rd, back end stepping out. China special tyres for roady before I bought it need upgrading.
in my dreams, i've been losing traction completely when turning onto burwood hwy from station st/tram rd. only in my dreams though.
Captain america got none of dem front delts brah, he be training forever chest and traps
And yea what Lee said, it's their job to look good so their diet and training would be pretty darn strict - not to mention some of the Hollywood 'supplements' they can get their hands on :P
I'm excited to get back into it all after my trip, gonna be so weak and lost all gainz :(
Edited by UNR33L
Units of VWL(BC) pls out-squat Birds and ask him "wat gainz lelz"
But agreed dat pleb lyf where there is always other shit to be done.
But I'll do it, keep you brahs updated on solid, thick, tight progress
:P :P
Incase the new GT6 PS3 massive updates annoy you, they allow a data logger to be installed into 86/BRZ/FR-S's and your real world track sessions to be replayed on your PS3. You can also race against yourself, in your virtual car, against your real car.
The downside, currently only available in Japan for Japanese tracks, and uber expensive. If it begins featuring Aussie tracks...oh lordy, I'm getting one!
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
