I was messing around with my trip meter and my finger slipped off the button, banging the cluster cover. This impact caused the globe in the odo to come back on, when I thought it was dead. Minor victories.
Hamish, I'm not a whiskey drinker. Recommend some to me?
I like dimple 15 but for the same money I prefer Glenlivet 12
if you want to start, minimum spend on a drinkable whiskey is ~$50
for a beginners scotch @ $50 you can usually get glenlivet 12, glenfiddich 12, dimple 15, balantynes 12, or chivas regal 12 - any of these are very approachable drams
If you are happy to spend the coin I would say the best one to start on would be Glenmorangie 10 year which will run you about $65
best value would be JW black for $38 @ dan's but this is a) not as nice as the above b) much peatier, which is not as beginner friendly
V lounge in Perth.
This flight qualifies me to platinum woo~ :)
strange I thought the V domestic lounges were meant to be better than the Q ones,
that said I have been told the lounges in Perth are not as good due to nearly everyone having access (FIFO perks) that they cheapened them down.
you lost or Leesh?
Ants pls
Leesh lost
I'm a trivia master
If only general knowledge could be translated into something useful and advantageous beyond cleaning up at trivia nights and going home with bottles of Johnny red and outdated street directories as prizes
Got some Chivas today :)
Ants pls
Leesh lost
I'm a trivia master
Off to 'million dollar minute' you go?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
