I was messing around with my trip meter and my finger slipped off the button, banging the cluster cover. This impact caused the globe in the odo to come back on, when I thought it was dead. Minor victories.
Hamish, I'm not a whiskey drinker. Recommend some to me?
I like dimple 15 but for the same money I prefer Glenlivet 12
if you want to start, minimum spend on a drinkable whiskey is ~$50
for a beginners scotch @ $50 you can usually get glenlivet 12, glenfiddich 12, dimple 15, balantynes 12, or chivas regal 12 - any of these are very approachable drams
If you are happy to spend the coin I would say the best one to start on would be Glenmorangie 10 year which will run you about $65
best value would be JW black for $38 @ dan's but this is a) not as nice as the above b) much peatier, which is not as beginner friendly
V lounge in Perth.
This flight qualifies me to platinum woo~ :)
strange I thought the V domestic lounges were meant to be better than the Q ones,
that said I have been told the lounges in Perth are not as good due to nearly everyone having access (FIFO perks) that they cheapened them down.
you lost or Leesh?
Ants pls
Leesh lost
I'm a trivia master
If only general knowledge could be translated into something useful and advantageous beyond cleaning up at trivia nights and going home with bottles of Johnny red and outdated street directories as prizes
Got some Chivas today :)
Ants pls
Leesh lost
I'm a trivia master
Off to 'million dollar minute' you go?
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
