I am a human calculator
I know this guy in Hallam who drives all these exy Mercedes
I'm surprised so many people I know get suckered into cheap car finance.
And I ask them, if car company is making a loss at by financing at below the RBA interest rate, where do you think they will make their money back from?
Residual value usually
driving through toorak & hawksburn reguarly when I lived in Burnley... would often see a lot of P-platers that were clearly 18th or 21st presents. saw a chick on red-p's once with the plates 18BDAY or something as gay as that on a 125i convertible. blaring something similar to Vanessa Carltons 1000 Miles. couldnt have gotten any more steretypical.
Any of you blokes who roll guards had to deal with lips that have been very very poorly smacked with a hammer? Unsure how to go about fixing it without pushing the outside of the panel about unevenly :/
You don't mess with club reg as it is your club and your friends that suffer if you get caught.
I will need it for approx 40 days for childcare pickups and 50 days if whatever I want (less 4 for attending club events) so that leaves me with a day a weekend legit driving (roughly)
You should be right; I imagine you'll be driving places the police have never heard of before
Ahhhh hipster jokes, they never get old...until someone else has heard them
So on topic of the FIFOs earning shitloads and throwing away their money, I met a couple on the weekend in WA
One asked me what I earn and then said he wasn't going to tell me what he earned, because I wouldn't want to know. I laughed and then he told me what he earned anyway, which was nice of him to do that. He bragged about taking home 12k in one month and pissing away 11k of it...which leaves him about on par with a 15 year old casual shelf stacker. Also expressed his concern about being able to pay back the remaining 15k of finance in his work ute...how the f**k? Then told me I should get into the mines. Thanks for the inspiration champ.
Pat I hope you are saving...
The best process is to stop being a bitch and just roll them
What do they usually spend it on?
Drugs & hookers? As there doesn't appear to be much to do in Perth
Have also heard that things are stupidly expensive up in mining towns... a $100 trolley of groceries can cost $150-200 in some towns up in queensland, purely because people have money from the mines... Pity about the "local" residents who can no longer afford to live in their own town anymore...
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
