Yeah glazes don't last forever though...they eventually wash out of the cobweb scratches and cobwebs come back. Need to give it a proper polish to permanently remove them. But I guess, cobwebs come back with polishing too just through contact with contaminants and wear and tear.
those are only minor cobwebs, they buff out pretty easy, even a hand buff will get them out..these brush wash cars and anything that has been though an automated wash is just messed up tho...the dull haze comes out easy but removing them swirls and scratches is a night mare
Correlation between good looking paint colours and how hard they are to maintain looking good lol
I guess it's part of the maintenance of a car.
Is this the Cutting Compound you and Artz talking about:
http://www.supercheapauto.com.au/online-store/products/Kitten-Cutting-Compound.aspx?pid=0078#Combo
that could work yeah....i'd go for the mequirs ultimate compound or scratchX though
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
