buffets are rubbish. substandard seafood 90% of the time too.
and who the hell eats the rubbish they leave in those heated pans?
hell, if i wanted 2 doz of oysters and half a kilo of prawns, they'd easily be less than 40$. and i can be sure they're fresh and properly prepped.
Edited by xALmoN
It's amazing how far your morals slide when you get paid $7.60/hour.
There wouldn't have been a week where I didn't make a point of stealing a few hundred dollars worth
(Usually alcohol/food)
Used to work at pizza hut as a driver... We'd constantly be like "Whooops, she accidentally put too much cheese on this one... Better make a fresh one for the customer"
Also, had a free-trade agreement with the subway next door... We gave them pizzas, they gave us bread which we'd put pizza hut toppings on and put through our ovens...
One afternoon not long ago at work, dropped couple of watermelons and cracked them.
Co worker and I decided to chop them, ate them and share it to others without mark it down as waste (we don't know how to as we weren't trained for that), t'was good snack.
/csb
Couple weeks ago, a elderly greek woman came to me when I did markdowns.
She complained of a product that isn't on special when 3 other products that are on special and she demanded me to mark that non-special product down.
I refused.
That is the last time she came to me (she'd been coming on me for weeks with different products), glad she's someone else's problem.
Yeah that's what I'm leaning towards...I always end up getting the same shit though as I don't really know much about the indian dishes and the descriptions don't sound too appetizing...
Butter chicken and a Korma usually get a run..
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
