is checking fuel pressure the best way to test if a walborough pump is working properly? or just safer to replace the whole thing?
Also chatting to previous owner last night (who is cautious, but also talks some absolute shit) and raised concerns about E85 on old fuel lines and seal (I have seen a document warning cars pre-2004 to steer clear of any ethanol blend because it eat through certian rubbers over time). He also mentioned E85 water/fuel separation if left stagnant in the tank for long periods of time... comments?
Please E85 propaganda experts, you're my only hope.
Fuel pressure combined with flow rate...
You can have a pump which can build up to 45psi over 2 seconds, and then a bung pump which can build up to 45psi over 10 seconds due to low flow rate... Only one of these is going to be able to keep up under high boost situations, do SR20's have a rising rate FPR?
We even for last night lol. But know you owe me twenty for actuator. But I owe you for muffler.
Where does it end!
Huh?
Why do I owe you for the actuator again?
I work on car for free then? Oh okay.
Hey everybody free repairs farken.
Im joking. I got one jd
This is not enough to cover an angry ass pregnant wife that thinks I'm having an a fair with scotty.
LOL @ an affair.
In that case... A slab of ze german beer.
Most of those documents regarding ethanol and old fuel lines are propaganda written by companies with a vested interested in keeping motorists using normal petrols or distributors being overly safe for liability reasons...
And we may spout pro-E85 propaganda, and then it becomes he says she says...
But the difference is, that the pro-E85 people actually have thousands of running vehicles from the early 90s to prove it's not an issue. Now show me all those explosions and fires and clapped out fuel systems from using E85 on pre-2004 vehicles :rofl:
E85 for 6 months and counting!
St Johns First Aid training course tomorrow
Sitting in a classroom with a bunch of other idiots all day... meh, still better than work.
Just remembered I need to memorise a 47 page pdf of pre-reading info before I get there, blergh.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
