deposits wont be sugar.
They are very likely a residue from soluble organic junk in your tank. Kept petrol for awhile? Some gunk settles at the bottom, i expect its the same for e85, except e85 dissolves that shit, and drops them when it evaporates completely.
If your bored on the weekend come around!
Otherwise was going to buy a solder on the weekend and fix my front indicator light, as the wiring as torn off
I'm working Saturday, but free that evening or Sunday morning?
I tried these first:
Narva plus 120
but only lasted about 3 months, moved to phillips, getting at least a year out of these.
No good. Didn't touch the bulb glass during installation, did you? Should have written them an email...they generally send out replacements when that happens in such a short time.
Obviously performance globes differ in life to standard globes but should be getting more than 3 months out of them.
hmmm I'll have get a stand... maybe a sponge would be good too for cleaning the tip (that's what she didn't say, cause she likes it dirty)
also should have lobster roll this weekend. good shit
nah use rubber gloves when handling them to be sure.
didn't want them again if die quick as you have to dismantel parts of the engine bay to replace, (either the whole airbox or the battery and cradle)
so changed up to phillips.
hey if i plod around in 2nd gear and low speed the car is quiet jerky
not beef jerky, but kinda engine revving jerky, almost makes me look like i cant drive
is that the mega cams doing that?? is it something i can tune out with more or less ign timing?
only happens on light cruise in 2nd gear at low speed, if i open the throttle it goes away
My car does this. Wasnt sure if cams or just setup. 3 different tuners and still does it, so not sure if tune will help
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
