read that a while back....
Asking for cooked sushi at Sukiyabashi Jiro
i wonder how she even got a booking? like you cant walk in... you would know of the place before you book.
like it is seriously HARD to get a table there... shit take major effort
I see what you may or may not have meant to do there
  • Like 2
Talk of writing car off 2 days after lovely result
Sadness
Desire to do it and buy http://www.skylinesaustralia.com/forums/topic/439783-r33-gtr-vspec-forged-engine/?hl=gtr#entry7289108 extremely high
especially as its Victoria proof
dilemma+
Sadness
dilemma+
negative. buy mint looking 4 door 33 on drift sales for 3 grand. drop your engine and shit in it. profit!
Sadness
dilemma+
yeah thought they might...its a bad corner to hit, not easily repaired...just buy back from insurance company and profit...
Sadness
dilemma+
Go buy the GTR
Then tell us what it's like once you are inside the inner sanctum of the GTR/Melbourne GTR/R33 GTR owners club!
  • Like 1
Yeah.. there's many options on the table.. some are 'easier' than others.
It's going on a hoist at Micolour today. Will have to physically have a look under there and see just how destroyed it all actually is.
The whole write off, buy back wreck is an option too, lots of messing around though.
Engine swaps are not always that simple either.
Only thing more Victoria proof than a boring auto R34 sedan, is something that is actually EPA proof
but.. 330kw @ 3500..
hmmmmmhmhmhmmmmhmhmhrrrrmmhmrmhmmaremarmamfgdFFS
Went through the exact situation as yourself
R34 write off
Buy back off insurance
New engine swap
Was a pretty straight forwardish process
R34 write off
New engine swap
you'd be absolutely insane not too after the money hes poured under the bonnet......
R34 write off
New engine swap
Were you with shannons?
How much did it cost, relative to what the agreed value was?
Some people have suggested this actually ends up 'making' money.
Who did the job?
Did you just do the engine, or the entire driveline, suspension, etc?
Mine is auto, there'd be a lot of wiring and random junk to do to. Most/all of which is undocumented and highly shit.
Pretty sure the assessor wouldn't know what his looking for mods wise so should be a low buy back value
Going to guess about $2k
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
