read that a while back....
Asking for cooked sushi at Sukiyabashi Jiro
i wonder how she even got a booking? like you cant walk in... you would know of the place before you book.
like it is seriously HARD to get a table there... shit take major effort
I see what you may or may not have meant to do there
  • Like 2
Talk of writing car off 2 days after lovely result
Sadness
Desire to do it and buy http://www.skylinesaustralia.com/forums/topic/439783-r33-gtr-vspec-forged-engine/?hl=gtr#entry7289108 extremely high
especially as its Victoria proof
dilemma+
Sadness
dilemma+
negative. buy mint looking 4 door 33 on drift sales for 3 grand. drop your engine and shit in it. profit!
Sadness
dilemma+
yeah thought they might...its a bad corner to hit, not easily repaired...just buy back from insurance company and profit...
Sadness
dilemma+
Go buy the GTR
Then tell us what it's like once you are inside the inner sanctum of the GTR/Melbourne GTR/R33 GTR owners club!
  • Like 1
Yeah.. there's many options on the table.. some are 'easier' than others.
It's going on a hoist at Micolour today. Will have to physically have a look under there and see just how destroyed it all actually is.
The whole write off, buy back wreck is an option too, lots of messing around though.
Engine swaps are not always that simple either.
Only thing more Victoria proof than a boring auto R34 sedan, is something that is actually EPA proof
but.. 330kw @ 3500..
hmmmmmhmhmhmmmmhmhmhrrrrmmhmrmhmmaremarmamfgdFFS
Went through the exact situation as yourself
R34 write off
Buy back off insurance
New engine swap
Was a pretty straight forwardish process
R34 write off
New engine swap
you'd be absolutely insane not too after the money hes poured under the bonnet......
R34 write off
New engine swap
Were you with shannons?
How much did it cost, relative to what the agreed value was?
Some people have suggested this actually ends up 'making' money.
Who did the job?
Did you just do the engine, or the entire driveline, suspension, etc?
Mine is auto, there'd be a lot of wiring and random junk to do to. Most/all of which is undocumented and highly shit.
Pretty sure the assessor wouldn't know what his looking for mods wise so should be a low buy back value
Going to guess about $2k
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
