f**k the lawyer shit, he'll end up getting nothing
Cave his f**kin skull in with a f**kin brick and you'll see instant results.
i like this.
had a solid week of hibernation lol.
our shop landlords got alzheimers.
keep forgetting who i am when he comes in lmao
531848_3611219493979_602685472_n.jpgMiss mine too :(
Now it's drift car with very ugly flared guards. :angry:
Mine went through a drift phase too.
Seems to have made it out alive
http://www.skylinesaustralia.com/forums/topic/329280-victorian-post-your-ride-thread/?p=5694184
If my car was stock i wouldn't have bought it back
Cept I did all my new turbo mods just before, and still had the Volk Te 37 wheels. So thought worst case scenrio wouldn't lose that much money
Process is easy if you DONT need a VIV
If you do, forgetaboutit....you may get alot of headaches...
Will need a VIV, once it's classed as a stat right off needs a VIV when it gets repaired, that's of course it can be, some repairs won't be allowed to be fixed
4 door 33 sounds like best idea yet.
>_>
<_<
Nice looking car that one, would be a sick setup
ah guess, not - saw wayne's old car on there too
Maybe the white one is my old car :|
Kinda looks like it with diff wheels, or has yours still got the same wheels?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
