f**k the lawyer shit, he'll end up getting nothing
Cave his f**kin skull in with a f**kin brick and you'll see instant results.
i like this.
had a solid week of hibernation lol.
our shop landlords got alzheimers.
keep forgetting who i am when he comes in lmao
531848_3611219493979_602685472_n.jpgMiss mine too :(
Now it's drift car with very ugly flared guards. :angry:
Mine went through a drift phase too.
Seems to have made it out alive
http://www.skylinesaustralia.com/forums/topic/329280-victorian-post-your-ride-thread/?p=5694184
If my car was stock i wouldn't have bought it back
Cept I did all my new turbo mods just before, and still had the Volk Te 37 wheels. So thought worst case scenrio wouldn't lose that much money
Process is easy if you DONT need a VIV
If you do, forgetaboutit....you may get alot of headaches...
Will need a VIV, once it's classed as a stat right off needs a VIV when it gets repaired, that's of course it can be, some repairs won't be allowed to be fixed
4 door 33 sounds like best idea yet.
>_>
<_<
Nice looking car that one, would be a sick setup
ah guess, not - saw wayne's old car on there too
Maybe the white one is my old car :|
Kinda looks like it with diff wheels, or has yours still got the same wheels?
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
