ah cos its absolute pressure
ie at idle or sea level pressure is 14psi or 100kpa already
so pressure is 262kpa, minus 100kpa
gives run time boost at 4800rpm
162kpa, gives 23PSI, geez
i wonder if thats right, thats from the vipec map sensor
the eboost one doesnt show that high
hmmmm
yeah not sure on the "statistics" page
some of them make sense, some are really way off
ie # of times started and run time in minutes seems reasonable
but then you look at peak ECU temp, 13000deg celcius???
max intake temp 12,000 deg
max volage 184
probably worth clearing them
but then kinda dont wanna clear the # of times started and minutes
Why, they are unrealistic too...
Started 36,000 times...that's 10 times a day everyday for 10 years and average 1 minute per run. Unless granny drove it to regularly and compulsively check for mail at the end of her driveway, or it had some serious starting issues, I call bullshit.
yeah the max temps and max #s are really really wrong
but the run time in mins and started sound somewhat believeable
i plan on keeping the car so ill probably erase the stats back to zero
cos it would be kinda handy to have some of the top scores over time
but currently theyre all whacko
cos it tracks # of times you hit limiter, #s injectors max, total knock etc
but currently they're all mega high
I felt an accomplishment driving into Bayswater @ Import monster and leaving without a defect today
fark that's lucky as! i heard pettit was hosting a defect shop near barry st bayswater today :s
nasty
whats the defect for
height below 100mm, pod filter unsecured pod filter and exhaust doesn't comply with noise standards. also have to provide a rwc. fun times :/
Luck of the draw mate, eastern burbs just increases the odds
true that :( booze bus turned into defect station.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
