Thought those kits were like $6k...
I would go supercharger, but only if roots type. The centrifugal ones are basically turbos anyway, just a little less laggy.
I think the turbo will be more fun and a roots blower better for drivability when you want to fang it.
Yeah basically!
Umm... both? hahaha To be honest, I'm not even 100% sure what I want, all I know is I have boost withdrawl symptons ever since selling my 33 and in search of my next boost hit :(
Reading this, go the turbo...it's obviously the spool and sudden rush of power from a turbo that you miss. Blowers are a more linear in their delivery! Though that centrifugal type will have a bit of a come on.
just pm him is all im saying.
mine worked out to be shockingly cheap.
I'm just assuming it's going to be way too much of a headf**k, especially with the crossover pipe from cylinder bank 1 to cylinder bank 2. Not doubting Scotty's skills, just trying to save him from a major headache haha
Yep, they're the eaton-style chargers and not the centrifugal ones (fake turbos I call them hahaha). I'm looking at the Magnuson MP2300 charger with 60lb injectors so I guess the $6k kit would be the ones with no injectors and using the smaller MP1900 charger :)
Turbo for that GATE
You boys are NOT making the decision any easier hahaha
Lumpy cam in a V8 with screamer? Should sound ok I guess haha :whistling:
VE GEN-TT Intercooled Twin Turbocharger Kit $ 7,995
if they sell for this in aus. they can be had for half price from overseas.
very easy to fit too.
Half? No way! Customs and freight will ream me to about the same price anyway won't it?
Also, I'm a f**king noob, I can't install that shit haha
Hahaha, yeah that's the only thing that is making me think supercharging, cos even though I LOVE the violent-ness of a car coming hard on boost with a turbo, the crappy commo would struggle to put that power to the ground I rec kon, even though it weighs almost 2 tons
If supercharging seems more straight forward and still retain the drivability, just go for that.
lt's still the same power out put yet can still use the power, for you setup.
someone say blown v8?
In my experience from actually owning turbo vs supercharged cars, I LOVE the 'rush' of power a turbo gives you (for me was my 33 GTR) but it has absolutely nothing down low, a v8 might fix that.. but you can't beat dem feels of full boost off idle too.
Making like 200+ rwkw at like 1500rpm means you can beat things without going over 3000rpm :D (ofcourse I'm only talking PD superchargers)
Around town / daily spec / less cop trouble supercharger ftw hands down love taking off from the lights no effort at all going through all the gears and being 100m infront of any other cars, fun / weekender I'd go turbo for the more 'lols'.
Around a track I reckon supercharger would be better with predictable power and straight curve, for skids can't beat supercharged v8 either :P
Both sound cool in their own way, I think turbo sounds will cause more cops to look at you though.
Edited by UNR33L
Do the SS's respond to strapping a charger on + tune as well as your GS did?
would make roughly the same power from what I've seen, biggest difference is my engine comes with the supercharger fitted on 'low' boost whereas an SS you're forking out another 10k basically. (not including supporting mods like exhaust etc)
the fact mine came with it from factory means cops can't touch me too, which is nice.
Edited by UNR33L
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
