Na they're good for some people, android are good for some people.
High end models android models are about the same price as entry model iphones, and are just as usable as iphones.
Specs aren't everything, so although iphone specs are a bit behind the 8ball due to their release cycle, the apps are designed for the specific specs... so the User Experience is the same. If you've got a low end android then you're going to have a bad time...
8 MegaPixel vs 16 MegaPixel.. who gives a crap... They both take great looking photos and handle low light really well. If you wanted a pro camera, you'd buy one, instead you're using a phone which is more than capable.
The Samsung S5 has a slightly sharper picture, the iPhone 5S has a slightly more accurate colour capture. Does anyone notice? No...
Personally, I'm an android guy, 100%... but the iPhone is still the best phone for some people, definately not for me though.
again. who?!
people who own iphones.
having swapped from an 5s to an s5, i wont be going back.
Reviewers for one. Most prefer the shots from the 5S. I use to work as a systems administrator and I currently do mobile app development, so I've worked with my fair share of phones from the different platforms.
Both iOS and Android are good platforms, I just can't stand the people who dismiss one or the other, it makes them look stupid and 99% of the time they have no idea what they are talking about.
This is true. The iPhone 5S processor is faster than the S5 though, even though on paper the specifications are lower.
Drip drip drip I wanna piss on youuu
sony z1/z2. waterproof yo.
Oh?
I know they're waterproof but are they beer-proof?
And do they take micro sim?
About rinsing, it could be a issue... Especially where I'm heading.
the f**k?!
just piss on it if you have too.
2013_0510_GetOutAlive_Bio_Bear-Grylls_90
Which cats got the tips / hookups for nurburgring drives, and also sports car rentals for ze autobahn
Looking at you Martin
Thanks for reminding me.
Martin the travel agent, show yourself please!
I used these guys:
http://www.rentracecar.com/?page_id=348
want to try their 86 next time in area
these guys also good.
http://www.rent4ring.de/en/
there another with a bunch of older alfa and such, avoid at all cost.
autoban I just hired a 3 series from avis did 220 no worries
Was looking at these sites just then, now to decide what car to use.
Should look around for lap tickets pricing. And decide what package should I go for.
Thanks Martin.
Also, whats the place where you go on a factory tour in Italy and you get to drive supercars or something?
Thanks Martin.
you mean these guys
http://www.motorstars.org/
if in the modena area as well I strongly recommend this new Museum
http://www.museocasaenzoferrari.it/en/
when I went there they had the history of F1 from early Maserati 250F through to senna's Maclaren and some newer one, all real cars dripping oil right in front of you
so not just a ferrari wank fest
Muchos Gracias Martin.
Gotta include Nurburgring, Oktoberfest, some of Italy, Greece, the sphincter of the universe and Russia, do wonder if I could fit Hungary and possibly someplace into the trip.
Off to do some planning.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
