^ this
also Ric you were right.. that dirt bike definitely wasn't a 'winner' after taking it for a 2 minute ride was leaking oil out the gearbox like a motherf**ker
Sell everything in your room and purchase new bike or one from a stealership?
^ this
I didn't say anything about the bike lol but you're welcome
twas me. wheres my credit dammit.
maybe i should charge $150 for an opinion on used cars...
D:\Games\DOS DOOM>dir
Volume in drive D is storage
Volume Serial Number is D326-902E
Directory of D:\Games\DOS DOOM
01-10-1994 08:02 PM 3,079 SIMPSONS.TXT
21-02-2012 05:24 PM <DIR> DOOM2
30-09-1994 10:47 PM 2,771,135 SIMP_GFX.WAD
29-09-1994 10:45 PM 1,250,002 SIMP_SND.WAD
24-01-1995 09:22 PM 56 SIMPSONS.BAT
15-11-2012 12:50 PM <DIR> DOOM
4 File(s) 4,024,272 bytes
2 Dir(s) 3,459,167,842,304 bytes free
Wastelanders, any of you guys know where to get service reminder stickers? Those little stickers where you place in the windscreen to remind you when to service.
Could only find American ones on ebay...
Or am I the only one having the trouble remembering?
I've got rolls and rolls of em. Grabbed em from a workshop that closed down who were selling everything off. You can have a roll if ya want. Going to any sau events soon?
Don't they come with each bottle of oil these days?
None of my bottles... Using Nulon
Was meant to go to the go karts one but prob not now.
You're not anywhere near the western /northern suburbs are ya?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
