If I was single with no kid I would work FIFO for sure!
I am used to incredibly long hours and hard work from a decade of cheffing... I was all set to go then I met the Mrs and well.... Banker
My perception of you these days
Bank error in your favour collect $200
School tax pay $150
Nah I disagree, It's just our media hating on mining FIFO
Farmers in au 150K+
FIFO expected to hit 63K 2015.
who get more attention and hate?
add to that look at the source
a new limited paper, ie hearld sun equiv in WA.
basically they hate the fact some-one earns more than then so tried to make the rest of the population feel better about themselves.
not spotting the same articles about, IT consultants, those that do contracts in places like UAE/kuwait, and for that matter pilots.
all who probably spend longer from home
anyhow I'm stopping now as just over this topic.
Thanks for the shares.
I recommend reading the book 'boom' by Malcolm Knox.
Australia has a culture where we cut down tall poppies. If someone has less/same skillset & capacity as yourself but doing better off we tend to undermine them.
Back in the 1800's when prospecting was fuelling Australia's population boom, land titles with mineral deposits came to the people who found them first. There was no skill as gold & other resources were sitting on the surface ready for picking up.
The people who missed out caused hate to the successful & hence why out history books celebrate the thieves who robbed the miners/prospectors & not the finders themselves.
Fast forward to today and a mining fifo role is a perfect example where people can compare against themselves. An IT role requires specific skills not common to everyone & hence why I feel they wouldn't cop the same hate.
  • Like 1
we don't
even though I could train a relatively smart monkey to do my job.
Do they get paid as well as you lot
and that there is the essence of the problem..
"you lot."
as yes every-one there is exactly the same.
do you think the site foreman is on the same as a engineer is on the same as an explosives expert is on the same as a dump truck driver.
would I expect a PT to earn more FIFO than one in Melb, yes for sure.
would they slot into the pay grades in an appropriate spot yes. is it going to be as much as Pat with a uni degree and years of experience, hell no.
anyhow most PT not be abel to work there as they do Drug tests so they would be screwed..
  • Like 1
"you lot."
+1
Everyone gets paid their expected base salary which comes down to their qualification & experience.
My base is no different to working my position in melbourne.
The difference in fifo is if your roster means 30% extra hours you get paid extra 30%
However like all other jobs, if I work beyond my contract hours I don't get paid any over time. (13/14hr days against my 12hr roster)
You do get an extra couple of thousand dollars for living away from home compensation but it's small change
    • Thanks for the linkie. Certainly always a great deal of help when people post comparisons like these, but I think for now I'll stay away from any semi slicks. I did go ahead and order the sportcontact 7. My buddy has them on his modified A4 and he keeps saying how good they are. For my intended purposes these will probably work real well. I'll report on them once I had the chance to try them out
    • Talk about noisy. Even when I still had the Tomei under the car I could distinctly hear the tires rolling. And I doubt I ever will need maximum grip like on a track. My GTR will maybe never even see the 600hp mark and I need to get used to the car quite a bit before challenging the limits of its handling. For the next winter storage I think I will get a set of these rubber drive-on thingies that have a tire shaped base. Those supposedly really help prevent flat spots.
    • Well our climate is definitely way less hot overall and the weather can be quite picky at times. I just know that during normal road use or even spirited drives there is no way I'd be able to consistently stay in the operating temperature, and constantly changing the tire pressure would also be a royal pain.
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
