breakfast is generally a ripoff anyway.
true but tasty
Unles its a buffet and yourself and your travel partner eat like buffalo I'm going with rip off.
Is a buffet and even has champane in it. but still
Which place? If you're staying on denarau just go get breakfast from anywhere.
Westin Denarau
stayed there b4 the the breakfast is epic, however after some research it is approx 25$ if you do a walk up and not include in room.
so yeah going with that.
seems they are just trying to sucker in people who looking to book with a package and not research what they doing.
true but tasty
Westin Denarau
Yeh just go for a walk man there's plenty there. Or just take one of those Bula bus things and go to the port.
I found when we were there I was knocked out and dead tired by 9pm, after a day of activities or exploring or even just kicking it on the beach... and of course starting happy hour at 4pm...
Was up before 9 most mornings anyway
my sleep time will be determined by tides.
gotta hit up some diving.
+1
I don't get it; they all look rare to me, only with progressively more searing? Well done is white inside and no red. So much for accurately describing to guests...
I had rare once, was really tasty but stomach felt funny afterwards.
bad but expected news for the pulsar: engine out, probably did bottom end bearing(s). the cause: most probably oil issues, like the whole oil cooler system wasn't functioning.
what's even worse is that now I'll pour more money into it... so many plans already. never ending
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
