breakfast is generally a ripoff anyway.
true but tasty
Unles its a buffet and yourself and your travel partner eat like buffalo I'm going with rip off.
Is a buffet and even has champane in it. but still
Which place? If you're staying on denarau just go get breakfast from anywhere.
Westin Denarau
stayed there b4 the the breakfast is epic, however after some research it is approx 25$ if you do a walk up and not include in room.
so yeah going with that.
seems they are just trying to sucker in people who looking to book with a package and not research what they doing.
true but tasty
Westin Denarau
Yeh just go for a walk man there's plenty there. Or just take one of those Bula bus things and go to the port.
I found when we were there I was knocked out and dead tired by 9pm, after a day of activities or exploring or even just kicking it on the beach... and of course starting happy hour at 4pm...
Was up before 9 most mornings anyway
my sleep time will be determined by tides.
gotta hit up some diving.
+1
I don't get it; they all look rare to me, only with progressively more searing? Well done is white inside and no red. So much for accurately describing to guests...
I had rare once, was really tasty but stomach felt funny afterwards.
bad but expected news for the pulsar: engine out, probably did bottom end bearing(s). the cause: most probably oil issues, like the whole oil cooler system wasn't functioning.
what's even worse is that now I'll pour more money into it... so many plans already. never ending
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
