My baby performed well, suspension setup and swaybars seemed really nice and planted :) The AD08R's were just amazing, I had no clue that cars could turn corners at that much speed and I still didn't even feel like I was pushing them at all :|
I'm having the same issue when logging in, every time gives me an error page after signing in..?
I think it's to do with the domain change recently. Change your bookmarks to www.sau.com.au instead of www.skylinesaustralia.com and it should fix it.
just for you HSV is putting the GTS supercharged motor in a maloo....
few tweeks and there you go
Whats the retail on one of those? *inb4 more than you can afford pal*
Need to finance it against my mortgage
Still don't quite understand some 34 GTR owners, buying a 90s car for 45k sometimes just doesn't compute.
I mean if you can afford it outright, sure do what ever the hell you want I guess.. otherwise just go the r33
eggzachary. but fanboys are fanboys. look at silly chaser owners. 15-20 yo toyboatas for 20k?!? just cos its slammed and 1/2j...
toyboys pls.
I used to think this way, but when you consider what else is around for the same money and the quality of it (or lack thereof), they aren't a bad buy if you can forget how old it is. Think it's more a case of the other cars in the Skyline range being undervalued for what they are. You get a lot more car than $6k worth when you buy a 33 GTS-T for example. Mine is bulletproof, or has been anyway, at nearly 20 years old. Meanwhile, people with brand new Volkswagens that don't look any good, are slower and breaking in 6 months...
New cars suck so much ass that I'll prolly buy 90s and early 00s cars for the rest of my life
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
