My baby performed well, suspension setup and swaybars seemed really nice and planted :) The AD08R's were just amazing, I had no clue that cars could turn corners at that much speed and I still didn't even feel like I was pushing them at all :|
I'm having the same issue when logging in, every time gives me an error page after signing in..?
I think it's to do with the domain change recently. Change your bookmarks to www.sau.com.au instead of www.skylinesaustralia.com and it should fix it.
just for you HSV is putting the GTS supercharged motor in a maloo....
few tweeks and there you go
Whats the retail on one of those? *inb4 more than you can afford pal*
Need to finance it against my mortgage
Still don't quite understand some 34 GTR owners, buying a 90s car for 45k sometimes just doesn't compute.
I mean if you can afford it outright, sure do what ever the hell you want I guess.. otherwise just go the r33
eggzachary. but fanboys are fanboys. look at silly chaser owners. 15-20 yo toyboatas for 20k?!? just cos its slammed and 1/2j...
toyboys pls.
I used to think this way, but when you consider what else is around for the same money and the quality of it (or lack thereof), they aren't a bad buy if you can forget how old it is. Think it's more a case of the other cars in the Skyline range being undervalued for what they are. You get a lot more car than $6k worth when you buy a 33 GTS-T for example. Mine is bulletproof, or has been anyway, at nearly 20 years old. Meanwhile, people with brand new Volkswagens that don't look any good, are slower and breaking in 6 months...
New cars suck so much ass that I'll prolly buy 90s and early 00s cars for the rest of my life
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
