Whats the retail on one of those? *inb4 more than you can afford pal*
Need to finance it against my mortgage
According to a article, you might just have to sell your taxi, bikes, brothers stuff without him knowing to be able to afford one with finance.
Simon if you can ever find brake pads for that kit I'd love to know, as I have the same Kit and Just Jap have no idea which pads actually fit it
which was fantastic
Richo runs them, so I'll get some advice from him... I guess the best thing would be to find out which car (if any) has compatible pads so I can quote that car when i'm searching for them.
They'll come with a set of pads, so I'll be taking some measurements and pics of them before they go in so I can be sure of what to get in the future :)
The QFM A1RM's performed really well all through the day, didn't let me down once... until they disintegrated.
HEL braided lines just arrived for the front, rears and clutch (dunno if they'll mate up to the new front calipers though), just gotta grab some decent fluid now and wait until I'll be able to install them :)
Want some motul brake fluid I won at sau dyno day? lol
Depends... do you know which one it is?
https://www.motul.com/au/en/products/oils-lubricants?f%5Bapplication%5D=144&f%5Brange%5D=25
The CP5070D54 sized pads fit. Most manufactures make these.
You can get them in DS2500/3000, HC800/Club Racer, Blue (DP5006)/Orange (DP9006) Stuff.
I really liked the project-mu, but it was costing too much. So used the Blue, then went to the Orange when I stopped driving it on the road.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
