Whats the retail on one of those? *inb4 more than you can afford pal*
Need to finance it against my mortgage
According to a article, you might just have to sell your taxi, bikes, brothers stuff without him knowing to be able to afford one with finance.
Simon if you can ever find brake pads for that kit I'd love to know, as I have the same Kit and Just Jap have no idea which pads actually fit it
which was fantastic
Richo runs them, so I'll get some advice from him... I guess the best thing would be to find out which car (if any) has compatible pads so I can quote that car when i'm searching for them.
They'll come with a set of pads, so I'll be taking some measurements and pics of them before they go in so I can be sure of what to get in the future :)
The QFM A1RM's performed really well all through the day, didn't let me down once... until they disintegrated.
HEL braided lines just arrived for the front, rears and clutch (dunno if they'll mate up to the new front calipers though), just gotta grab some decent fluid now and wait until I'll be able to install them :)
Want some motul brake fluid I won at sau dyno day? lol
Depends... do you know which one it is?
https://www.motul.com/au/en/products/oils-lubricants?f%5Bapplication%5D=144&f%5Brange%5D=25
The CP5070D54 sized pads fit. Most manufactures make these.
You can get them in DS2500/3000, HC800/Club Racer, Blue (DP5006)/Orange (DP9006) Stuff.
I really liked the project-mu, but it was costing too much. So used the Blue, then went to the Orange when I stopped driving it on the road.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
