Pretty much why I went the GS over GT at the time (3 years ago now) they were like 50s vs 70s new (depending on options), just tuned it up to make more power than the GT anyway.. I'm missing the brembos but that can be done for 2k brand new 6pot kit..
New XR8 and mustang do look the goods
Edited by UNR33L
Fk the last of the GTs...new XR8 with the supercharged 5L for less than 50k
yes but your not buying it to drive are you, it's a collectors item that will only appreciate.
same as the last monaro sold for 200Kish.
Continuing my tirade on social media and people not actually giving a f**k about the celebrities they post condolences for
http://mobile.news.com.au/entertainment/celebrity-life/richard-attenborough-dead-twitter-mourns-his-brother-david-attenborough/story-fn907478-1227035777817
What's more worrying is that people still read news.com.au :P
Martin where and how did you book acommodation for Fiji? Wanting to stay somewhere else other than whyndam for a change(read: ran out of freebies)
although it sounds bad..
I look on hotels combined/trivago
that said. after you find the price on another site always check the pricing from the hotel website itself.
if that the same as an online booking one, book direct to the hotel.
The hotel makes more money and your much more likely to get a room upgrade/free spa treatment/food voucher.
if the online one cheaper tho, go it.
Thanks
Where are you staying?
well we have not booked yet, there booking rate for the period of our stay is low, so holding out for some specials closer to the date.
last time we got a 2 nights for price of 1, and a free bottle of wine and a room upgrade ;)
But the plan is The Westin Denaru
a few site like booking.com tell you when more than 50% of rooms for a period of time are taken.
So I use that to gauge if there will be discounts or not.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
