I just wanna tell you how I'm feeling
Gotta make you understand
lay the clingwrap out on the bench, try to have as much space as possible and lay it so the clingwrap is flat on the bench like a carpet.
put the meat on the wrap and start rolling. roll away from yourself.
put your hand past the sexy meat wad and with your other hand give it a gentle pull while you roll it to keep the clingwrap tight.
you can give the meat a little squeeze at each end while rolling to stop it from coming out the edges
repeat again and again
  • Like 1
cant believe hamish endorsing breadtop... their bread is like maccas as its considered confectionery...
but want to try that burger recipe. need to hunt for good mince
It's for an American style burger. it needs to be sweet
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
