Have heard people just whack an eBay manifold on the Ford 4L and a GT35 and run low boost no problems
Would be pretty funny to try with an old piece of shit
Hmmmmmm intradesting I have my grandfathers old el sitting in our paddock :P
they do motorbike and misc. machinery... its all about getting parts really.
after speaking to our mutual friend yesterday, i dont think he's too keen on cashy's at the moment. the workshop will take em though.
after seeing the motor yesterday, needs a replacement crank :angry: (good thing i didnt go stroker kit)
dude... it took you 2 years to change a set of rims
that's cos it's my own car. Plus all monies went to buying apartment instead of unnecessary mods.
Well he builds all sorts of engines
He probably rebuilds an engine a day, not just high performance, lots of insurance ones. So i'd say he's dealt with a wide variety
so does he need engine out or does he engine out, rebuild and reinsert? The less car I need to work with the better. How does this work, do you have to put in an intro or do I just call him and be all like "Tony said deal with it"
Correct
Cash job just means you get paid for the service in cash. Amiright?
But is it tax deductable?
On a side note, I do have an accountant friend with a few years exp that might be interested. He just got married and is on honeymoon atm though...
unnecessary mods like fucking what? a pair of cashmere wheel changing gloves?
  • Like 1
He can do it all *if* he isn't busy
Best to just shoot him a PM, just say your from SAU and Tony told you to contact him through it
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
