They were just my thoughts when i jumped into my gfs dads 135i. Was brand new and wondered how much it set back with any optionals. Beefy torque.
No idea what they cost second hand though.
Glw search
Nice car, I can just squeeze in the back seat and admire the quite average dash.
Better get an M badge off eBay before you purchase one
As opposed to a pulsar where the only thing you can admire from the back seat is your quite average boyfriend
  • Like 2
at least his wife doesnt have to pick him up from public transport stations.
car : petrol $50/week + Parking $50/week = $5200 per year just to get to work.
train : $19/week = $988
net saving to Hamish = over 100 slabs per year
i'm happy with the piss covered seats, spotty 16 year olds and rascists.
Pretty low risk on the Sandringham line I'd have thought
This ^
Clean trains, with no junkies, and on time... every 8 minutes. It's the only line that is like that though :P
youd like to think that.
but straya.
Police would like to speak with four women who stopped to help a man that had been stabbed at Elsternwick railway station yesterday evening.
The stabbing occurred at 7pm when a 27-year-old Windsor man travelling along the Sandringham line train towards the city got off at the station with a group of about ten youths.
It is believed a verbal altercation broke out between the 27-year-old and two youths from the group, escalating into a physical fight.
but hamish wouldnt speak up about whatever those youths where doing.
he would just write a scathing facebook status.
so you'll be fine buddy.
stab vests are pretty cheap tho. just saying.
  • Like 1
I wouldn't be able to help, I'd be too emotional and teary from one of Paul's facebook posts about how society doesn't care about ex soldiers
if only they where about muslim soldiers.
then you could jump on that band wagon too.
sandy line is pretty good (in comparison to other lines).
but where theres public transport, theres dead beats.
now everyone just calm down and put on some bob ross while they work.
http://www.dailymotion.com/video/x1hsyf7_bob-ross-the-joy-of-painting-s3e2-blue-moon_creation
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
