It isn't one of those fancy laptops with a 3g card in it?
As in, not actually on your wifi?
When I log in to my router it shows the new laptop as connecting via Ethernet.... Everything else (other laptop /phone) are connected via wireless...
Inb4 VWL internet speed test screenshot pissing contest
truest truth ever trued
f**k that is tempting....
If it was manual.......... I might think about a chaser next... have wanted one for ages
Why the f**k does everyone that posts masallah insallah meibruk or whatever the f**k you're saying, only say that one word in arabic and the rest of the sentence in English?
inshallah = god willing
mashalah= thank god (loose translation)
mabrouk= congratulations
manyook= cock sucker
ayr= cock
jahash= dez
hmar= dez
ayer bi teezak = platts favorite phrase.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
