whats wrong with it
bought new laptop
it connects to my wireless, but every page loads slow as and sometimes doesn't load at all...
signal strength is strong according to windows
was dropping out repeatedly last nightth
when logged into the router it says its connected via ethernet not wireless like my old laptop and phone say they are
30 day return policy as long as you can wipe all traces of your sleeve tatted beefcake jizz off the keyboard.
wait.. wut? wasn't the 3k model like $200 over your budget?
Any more info on this return policy? This thing is a f**king piece of shit
