Greg I really feel like posting this in your spare parts thread
Take Greg's parts, but beware...they carry a terrible curse...but they come with free postage...the postage is also cursed...but you get your choice of carrier...the carriers do not offer postal insurance............that's bad...
  • Like 1
resized_winter-is-coming-meme-generator-
but only cos Ash loves you..
I am OK with this.
You should know, any part I have actually sold, I have given this disclaimer in person to every buyer.
lol...
