Vue De Monde is overrated
It is. Massively
It was better when it first opened and Cory was the head chef.
Chefs who cook rare steaks are just being lazy
This is just silly, they (generally speaking) cook it how the customer orders it.
R34s are clearly the best looking and most classic Skyline shape
I know you like 33's more than 34's and that you think 34's look out dated yet not classic. hence obvious troll is obvious
Corollas are shit unless we're talking the 90s fwd model that actually looked and went alright
In standard guise, the AE93 corolla GT actually did look and go well. That was actually the car I used as a front cut for the 4age I put in my KSEV. They were also comfortable and well appointed for a cheap economical little car.
RacePace
I have noting at all against race pace in the above usage as it does not relate to my complaints about pricing
The west coast pretty much invented hip hop, the best thing the east ever produced was Young MC
THIS IS TOO FAR
The Japanese have terrible scotch
They don't make scotch, they make Japaneses Whiskey. Scotch Whiskey must be made in Scotland
Nurses are overpaid
this one gets me..... I have no answer for this
Dr Pepper should be available everywhere
I have no problem with this. I even enjoy the occasional sneaky Dr Pepper (read once a year tops)
The DJs of today are much more talented because they have to use more advanced technology at their gigs to stay competitive with other DJs
If only David Guetta tracks were around in the late 90s, then we could say techno was good back then
YOU ABOUT TO DIE MOTHERFUCKER
Hypergear turbos ftw
Hypergear have improved greatly over the years and now manufacture some amazing turbos that not only offer great value for money but also give impressive power gains without compromising on response
Everyone should copy me and start using E85, it's actually good
this
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
