Exhaust, tune, and enough boost should yield anywhere up to 300, that'll keep me entertained. Not sure about stock power, maybe 180 or so. It's massively held back from factory
Feels good Alex, cops / other hoons seem unaware which suits me fine. Trying to fly under the radar after the theft
On my old 335i, I had:
JB4
Downpipes.
Air filters.
Charge pipe.
Meth kit.
That got it to exactly 300rwkw. If you have the n54 engine, just get ready for HPFP and Injectors to die lol....
Nah not much cheap going around here depending what you wanna spend Id investigate waterline in Williamstown new development of apartments hot location long settlements can't go wrong
Trust me I'm a salesman!
Have you got dual clutch ric?
What kind of rent prices are they looking at their Alex?
To be honest I don't really care where or what I buy, as long as the rent I get is decent, and it's newish so I get the tax benefits (my understanding of that aspect is limited, but from what I've been told, newer the better)
Budget would be up to about $400k I'd say
multi million dollar apartment, kgo
Nah I've got dual balls so bought a manual ;)
JB4
Downpipes.
Air filters.
Charge pipe.
Meth kit.
Already replaced under warranty thankfully! How'd you find it at that power level?
JB4
Downpipes.
Air filters.
Charge pipe.
Meth kit.
Nice
If the 4 door weren't so ugly it would be on the consideration list
Not sure man it's not my core area but it's blue chip so I think you'd get a decent return
Very good.
Power was linear and it was a fair bit quicker than the e93 m3 that I replaced it with.
Best of all, it wasn't too expensive, all up it cost around 3 to 3.5k including labour.
Nice
Yeah the e90s look a bit dated now. That said I've seen some nice examples...
  • Like 1
Decisions shouldn't always be around tax
Just because you get about 30cents back for ever $1 you spend doesn't mean you always should
Know what I mean jellybean
  • Like 1
I'll speak to Jess about it... she was gonna handle my rental anyway..
Not really, no.
But yeah obviously there's more to it than tax benefits...but if the rent is a good amount, and there's demand to rent there, then in theory it should be ok..
Rental prices dropping in clayton.
Went from house on half-block in clayton to same size house on bigger block + outdoor area and garage in rowville for $50 less a week.
Old house was on the market for over 6 weeks and had to drop $20 a week to fill it.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
