You don't need new anything, you need a fuel system that supports the flow capacity
If your current stuff can do that then you can keep it
New lines and rail are unnecessary, pump and injectors is all that really needs an upgrade assuming your current ones are unfit
well that would be stupid if he has something that will obviously not make it, like 500cc injectors for example
he would just have to pay for tuning twice....
although that WOULD be a fairly Mohsen result
  • Like 1
What injectors / fuel pump / etc are in the car at the moment?
You're not making insane power so don't worry about lines / surge tanks / rails at all.
I would look at estimated power levels and install injectors and fuel pump to suit, before the E85 tune, or you'll be back to Racepace 5 times over the next 2 months and complain about it every step of the way.
exactly.
car has
walbro 255lph pump
stock injectors
stock rail.
wouldnt take any more ignition timing and detonated when more boost was added. so gonn get some cam gears and hopefully solve that problem.
current wish list is z32s, id1000s, cam gears and some brand new coil packs.
car has
walbro 255lph pump
stock injectors
stock rail.
call scotty right f**king now.
Someone did that in the test lol
Object fixation is a bitch
Never look at where you don't want to go lol, at least until you're experienced enough to control the bike independently of your vision
I'll know when I'm there if I don't hit a pole after looking at it
Can't remember what color is what... Then Broadfords colors are different again just to make it worse
From memory white is slow / inexperienced, green is moderate / experienced (2 minutes and above laptimes), red is balls out / below 2 minutes.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
