Well.... To actually have full grip they'd need to be at about 30psi hot... which would mean near 20psi cold / normal driving...
If you're running at 30psi cold... once they actually get up to temp then they'll be 42psi.
Note that "Hot" does not mean "I've done a quick burnout on them before a launch"
You're going to have an absolute ball on them if you dial them in properly on the track.
Found the tyres surprisingly good for the price.. either that or I was too used to driving around on complete bald shit.
Some girl even told me she 'loved my car' on the way home as she crossed the lights.. must me the Achilles.
  • Like 1
Unlikely after how much I just spent on my bike....But I'll have a browse... I do enjoy buying shit impulsively
I'm up to ~$150 with my frame slider kit and Yoshimura spools / bar ends
Not sure if should gold the shit out of everything or Yoshi the shit out of everything
Fkn lol. Heyyyyy Achilles! Call me...
You forgot to mention if she was hot or not
she looked like an 18 year old school girl, was pretty decent actually & wearing those tight pants, datass. Wouldbang /10
i should of offered a ride
WITH MA DICK
Edited by UNR33L
  • Like 2
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
