At least they took it before you spent the money at revzilla..
Too soon?
Never too soon.
Stolen from underground carpark in Boronia
Much like Ric's Skyline
how do u steal a bike?
srs
besides picking it up and chucking it on a ute
This is pretty much what they do.
I had a disc lock on it with an alarm and it has a steering lock too.
They would have had to remove the front wheel and lifted it up / dragged it out of there and wheeled up onto a ute or something.
Guessing they nicked it for parts.
Yes I'm insured.
Pull up at servo... Car in front is just past the pump, looks like they're leaving.. Starts to reverse past the pump towards me... I beep to notify them of my presence, as if it wasn't obvious enough already.... Continues to reverse until our bars become one.... Then does a runner...
Chased for about 5 minutes... Not an easy task keeping up with a ba falcon in am excel but I held my own. Lost them eventually.
Now they just better hope I don't see them again. 450mm shifter is hanging to tighten some nuts
Revzilla sell nuts
Did you get rego? Servo would have it on camera...make the fker give you a new bumper even if it's not damaged
My neighbour spotted 3 motorbikes hanging around our driveway at around 1pm today and some old guy talking on his phone in the carpark. Gotta be then. Fking flamin mongrel motorcyclists...so much for being something of a community.
The disc lock on the bike had an ear piercing alarm so I don't know how they pulled that off without anyone hearing. Must have been no one home in the complex.
So I have a time and a description, there's shops on the streets all near me so prolly CCTV that would have got three bikes riding along...I have a screwdriver left behind that could be finger printed by the cops if they decide to do some detective work, but let's face it they prolly won't bother over a theft :(
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
