f**k nick you have no f**king heart you should be ashamed of yourself, that man risked it all for us, hitting balls with his wood.
youre unaustralian nick, you piece of shit - every ninemsn/aca/news commenter.
I would laugh to actually see you commentate the news one day LOL
Hmmm cricket doesnt claim many lives
There are other things that don't too, but people still die, just no one hears/cares about it
Many people may have followed or idolised him
For him to die from a freak accident whilst playing cricket is kinda sad
Made me a bit sad nohomo.
Everyone is different, there have been other celebrities that have died that I don't really care much for but then there are some that I may have gone cot dayum that's sad
tells news bitch ill feed her my cock on air, look at the camera and say "that was no mistake ulehs"
True, I guess I'm a bit numb to it all though because of work
Not trying to take anything away from his death, just to the people that jump on the bandwagon more because he was well known
Yeah fair enough. Sall good!
For some people i think its just the level of connection I spose
Say if a soccer player died, i would be like, oh that's sad, but can't say I know who he/she was as I don't follow soccer.
Rather than say for me a Phil Hughes were I grew up watching and playing cricket
  • Like 1
id ask for you and ric, dez in the chopper, "THIS TRAFFIC IS A COCK SUCKER"
Yeah I get how people grow up with them etc, but to me everyone is equal when it comes to death. I don't believe the famous should be idolised in death as they were in life
take for example Carl Williams, people were coming up to me in Keilor Cemetery asking where he was buried etc, I mean the guy was a criminal and people just wanted to know everything..... Although underbelly was awesome
Another rejection, looks like I'll have a mech eng degree with no job ever.
Hard luck mate. Keep at it...get enough apps you get an interview, get enough interviews you get a job :)
Game of numbers sometimes
  • Like 1
just get grant to build one then wait for him to go drinking beer in europe again and have to sell it......
lol sif sell it for drinking binge in Europe.
The wrx on the other hand...
grant why you got 2 cars now? lol
Because a f**king curry drove into the back of the R and insurance took f**king ages to decide to fix it.
The r is now at panel beaters. Needed something fun to drive around so bought a 180kw atw wrx.
I do often get to the final stages of interviews after tests and pre-phone interviews but making that last round to secure the job is almighty dam hard.
Leesh, 32 rejections from 32 schools??
moved to different camp, wifi/internet is almost unusable plus bans on any entertainment and car websites and telstra has next-to-no 3G reception...
the itching begins...
#1stworldproblems
#1stworldproblems
Time for you to either gtfo this camp or start a riot.
will be here maybe 3 nights. just have to keep watching movies and/or be patient.
1 week to go then (hopefully) extended christmas break and chew up all my annual leave. or back to regular 7-3 hours.
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
