House parties are the way to go, or in the loungeroom at home with a scotch and an ironic 45 on the decks you spun 10 years ago back when you were mainstream and uncool.
this any time.
think will drive up the country and have a few beers with my mates this year, shed party...
East west link would be alright, but using it to drive to my job where my hourly rate has just been cut in half, along with everything else they want to strip us of, not so much.
I didn't hear any of this from liberal ... Was this Union scaremongering?
This was my point.
Labor scaremongering would have you believe the Liberals will decimate the state like Skynet in The Terminator, where "big business" will destroy everyone but themselves
Liberal scaremongering would have you believe the Labor will decimate the state like the Tripods in War of the Worlds where "the unions" will destroy everyone but themselves
It's the same shit, just a different title.
I cant believe people actually fall for it.
anyone that voted for labor, just because they will scrap that tunnel is going to very disappoint.
as if a political party backed and controlled by unions is going to cancel a major construction project.
heres to the east west tunnel opening maybe 6 months later than it would have under the libs.
I suspect those people largely voted for the Greens... who continue to trumpet their own relevance despite holding probably 1 of the 88 seats in the lower house
dont get me started on those idiots.
f**k the people save the enviroment.
as liberals would not have had a delay..
oh wait I hear what about the nagambie bypass, delayed over a year...(sorry this was the most recent I could think of built in past 4 years)
built under the liberals.
burnley tunnel.
massive issues had to be closed and repaird
built under labour.
seriously they as bad as each other
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
