but UK living expenses so spensive
thats why you live up north mate. 2 dollars a pint, houses are about 90k aud. jobs pay about 35k aud and everyone is nice, cos you have the same thing in common. you hate southerners.
*disclaimer
prices are relative to me leaving in 08/09.... may or may not be higher now.
*disclaimer
Sounds like my kind of living. What sort of land do you get for 90K?
Hnnnnnng that garage tho
http://www.realestate.com.au/property-apartment-vic-clayton-118326151
What you think Alex? might check it out.. I was looking more closer to the city but get shit all or something really old for your money the closer you get :\ Also this is across the road from Coles which is nice..
Edited by UNR33L
Looks ok man but suss out the body corp situation it can be high in those developments for bs things
bitch of a location IMO. level crossing causes traffic to bank up and no one in clayton can park or drive very well.
that, plus if they decide to get rid of the level crossing... thats traffic woes and construction for 6+ months
Also, theres 2 coles there. both stock the same shit and its not very diverse. i used to drive the extra 5mins to safeway on warrigal rd.
It's right across the road from Coles, that is the reason alone you should go 'shut up and take my money' mode.
And no, you won't see me covered in blood there.
wow 81sq including garage, I've stayed in hotel rooms bigger..
thus why I'm looking out of town.
I thought the 81sq was excluding the garage.. they usually do exclude the parking / storage in apartments I thought? if it's included then that's pretty bad and not worth looking at then lol.
Edited by UNR33L
Apart from a little traffic / possibly noise (would need to have a look) I kind of liked the location, near heaps of shops and the station would make it pretty easy to get into the city, walk across the road, grab a BBQ chicken dinner done.. :D
Inb4 walking across the busy road, get hit by car & ambo doesn't save me cos' shit wage
Edited by UNR33L
Clayton aye. Suburb across from me :thumbsup:
Also inb4 Korean girlfriend
from line under diagram seem to be included.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
