just bare in mind here fellas, the gps hardware shit you use on your phone, is a once calibrated piece of junk.
use a seperate designed for piece of equipmunk, and make sure its calibrated.
also, enviroment plays a huge part in gps signal. so dont just rely on that.
not saying whats above is wrong, just giving you all the info.
don;t use the gpn on the phone,
I use an external 10Hz GPS reciver liked to racechrono on android.
the lap times are withing .1 of a second of the track ones, (think it more due to the start stop line in racechrono is not the same as the beam they use for our track days)
so think the results are fairly accurate.
assumed that but thought would clarify.
when I used the GPS jsut on the phone times were more than a sec out from lap times, the external GPS as mentioned brought it down to sub .1 so I'm happy for the time being.
  • Like 1
If you need to be accurate to less than 1/10 of a second for recreational racing... you need to get a life lol
If you want an accurate representation of how well a different line through a corner effects your time, then having an accurate GPS is pretty important.
I use a 10Hz Bluetooth module as well, stuck to the top of my windscreen, because I have my phone wrapped up in my centre console and GPS Reception when you're inside a big metal cage isn't ideal.
Lap times can be within a 0.1 seconds... however things like top speeds and corner speeds go absolutely retarded if you've got a poor signal and it thinks your bouncing all over the track.
What if you drive a BNR34
Them you don't need to be timed as that is below you. You already know you are the fastest. Even faster than the RWD guys going faster than you
  • Like 1
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
