Leaning towards a standard one for half the price. 600hp is a fair whack of power, but I assume that's at the engine, in which case the turbos and current tune are already putting that out on 98...and I'd like to go ethanol. Revving that other one to over 9000 would be ridiculous
There's just something so spastically awesome sounding about a 3 litre twin turbo all wheel drive on ethanol, before I've even heard the exhaust note
This may have just gone from a possibility into a must do
  • Like 1
Ad doesn't say sold. Hence my curiosity.
After he comes along to a meet
And shows us his girlfriend
how about you come over to my house and be my wife boy.
seriously
hamish.
mums gone OS.
i can only cook and eat so much bolognaise, steak, salad and veggies.
give me nice soup recipe, or chicken roast. k go
seriously
hamish.
mums gone OS.
Eggs fgt
why 9000? its like saying pushing your turbo to 40psi. its a nice number but unnecessary if setup properly (for street and occasional track use)
congrats hamish. when you getting torago?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
