serious talk time fellas.
have you all ever gotten so over everything you feel like you are working to achieve nothing, like no goals, no aspirations. just working
and before anyone says find a new profession, i like this job. it pay well. but everything else is meh.
wake up, shower, work, relax, fap, shower, sleep.
i cant even be f**ked chasing chicks anymore, and my temper is getting shorter and shorter. what the f**k.
in seriousness
http://www.beyondblue.org.au/
or on a slightly lighter note
http://www.mantherapy.org.au/
  • Like 1
Make some lifestyle changes moh
well no make some positive lifestyle changes.
if the lifestyle change you make is smoking vast quantities of ICE..prob not going to help.
The Man therapys site has some good ideas on where you need to look and suggestions to help.
all from the context of a man cave.
(it's run by Beyond blue as well)
Man therapies was enjoyable.
you smoke? eating well-ish?
person ive been hanging with lately has some issues and i think a lot has to do with diet and not having enough energy to do things.
lost my shit hahah
i smoke, have cut down the crap food intake. really just cook at home.
like last night, i declined a kebab and had the arab bean sprouts i had cooked lol.
i hardly drink now, like a stubbie or two at the very most.
ill sus those websites out
its really strange because one minute ive got everything under control, next minute im losing it and feeling like smashing something.
have another ct scan in 3 months. doctors thought the cyst might have something to do with it.
lost my shit hahah
how about your realise your not some little bitch, and man the f**k up.
life is shit. its hard and doenst get easier unless you win the motherf**king lottery.
if you need a hug, come get one, then im gonna smash you in the other eye socket, cos thats waht life does.
الكثير شقيق الحب
Where do you see yourself lacking in the above picture? Work on balancing all 5 if you have focused too much on the others.
It's why Ive moved back to Melbourne & getting ready for 4hr flight to Perth. Exit row to my self for free.
Seriously Moh, you had your well paying job given to you on a platter, hence the complete lack of appreciation for how good you have it.
If you had to work to be where you are you would have an appreciation for it and a sense of fulfillment about life.
Now quit sooking and sell some f**king ovens you spoilt shit.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
