To be honest, I never really used flex fuel.
Seems good, in the real world once you're on E85 you don't need 98, as the availability is fine unless you're driving to Mildura etc.
That said, flex isn't very hard. All the ECU needs to know is ethanol % which it turns from 0V to 5V.
Then the ECU takes that input which may be like 2.5V, and applies a certain percentage of a correction map to fuel/timing/boost, relative to the voltage of that input.
That's all there is to it
  • Like 1
i regularly drive to brissie.
Then I suggest you get a wideband and flex fuel
Wideband because playing with correction maps is likely going to be needed if you want it perfect. Its quite time intensive and expecting it to be PERFECT from a few hours on a dyno will never be feasible.
There's a lot of "hm, I'm idling at 13.7 AFR when I'd like it to be 14.7 when I am on 72% 98 and 28% E85" goings on
then again, can i justify paying 3k or so to make car flex fuel capable? 800$ for injectors, nistune, 1k +-, sensors and stuff, 1k, scotty intake 300?
i'll still run stock turbo.
Running E85 on stock turbo is really not a cost effective/convienient solution
Technically speaking, all E85 does is removes limitations of less than optimal systems, its not like you're gonna slam 30PSI into a stock turbo with a ton of timing for other explodey reasons...
If you could hit MBT and Peak compressor efficiency from your turbo on 98 without it pinging to death, switching to E85 wouldn't give you more power, I've been told that's why some people see big gains from E85 and some people don't
There's still gains to be made from advancing the timing and taking advantage of 107 octane.
Boost will also come on sooner.
But I think if you're spending that much on upgrades you should at the least get an $800 high flow and get another 60-70rwkw out of it while you're there, sacrifice a bit of response given the factory turbo is responsive and linear enough let alone with E85.
Technically speaking though, advancing timing only increases power to a point, after a point it starts reducing power.
If you're not pinging at that point, on 98 well, you don't need E85. It's possible in some lovely systems to not be pinging at MBT.
Same thing re: Boost pressure.
But in the real world, where we do stuff like add turbos to systems designed for lesser turbos, well, E85 starts becoming cool.
Would be curious to see what happens on a stock system, but you aren't gonna run more than 10psi on it anyway.
I would wager youd gain more powars per dollar by upgrading to a hiflow on 98, vs converting to E85 on a stock turbo.
so. 4k? LOL.
I'm planning on moving to the country, so there will be winton days on 98 and any tracks in city E85
saves me having to do a run down to MELB with jerry cans to do a tampered day.
Planning on going north?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
